This is the documentation for the latest development branch of MicroPython and may refer to features that are not available in released versions.
If you are looking for the documentation for a specific release, use the drop-down menu on the left and select the desired version.
2. Making a UART - USB pass through
It’s as simple as:
import select
def pass_through(usb, uart):
    usb.setinterrupt(-1)
        select.select([usb, uart], [], [])
        if usb.any():
            uart.write(usb.read(256))
        if uart.any():
            usb.write(uart.read(256))
pass_through(pyb.USB_VCP(), pyb.UART(1, 9600, timeout=0))
