This is the documentation for the latest development branch of MicroPython and may refer to features that are not available in released versions.
If you are looking for the documentation for a specific release, use the drop-down menu on the left and select the desired version.
11. Power control
pyb.wfi() is used to reduce power consumption while waiting for an event such as an interrupt. You would use it in the following situation:
    do_some_processing()
    pyb.wfi()
Control the frequency using pyb.freq():
pyb.freq(30000000) # set CPU frequency to 30MHz
